Wav trigger pro and microSD extension cable
Hi to all
I’m using a trigger pro in a sample-based stompbox. In order to ease the frequent microSD handling in a small place, i bought this microSD extension cable:
The trigger doesn’t detect the microSD thru the extension cable at all.
Is the issue this particular cable, so i should try a different kind? or is the trigger itself that demands the micro SD being inside the onboard reader?
Thank you so much
The microSD card bus is extremely fast, on the order of 50MHz. This is necessary to achieve the kind of performance offered by Robertsonics audio players. As a result, the routing and trace lengths of the SDIO signals to the card are critical to proper signal integrity, and any time you mess with that you risk corrupting the signals. Furthermore, this extension cable does not really provide adequate documentation. It appears that all of the pins are passed through, but without a schematic, you can’t really be sure.
Any given cable may work, but it also may not. The longer it is, the less likely.
I’ve gotten them to work with the 2nd product here https://www.sparkfun.com/catalogsearch/result/?q=sniffer if you want to give one of those a whirl (if that’s enough length to be helpful!)
