is it possible to set the WAV TRigger to MIDI Mode with a Serial command and
then switch to the MIDI Serial Input ?
Christoph.
Christoph.
Hi Christoph.
There’s not a command I’m aware of, but you can turn MIDI on by enabling that in the INI file on your SD card. See [chapter 10 of the users guide for more information about MIDI and [chapter 6 for information on the software that generates the INI file. (Init File Maker utility)
You can find the Init File Maker Utility software [on this page.](https://robertsonics.com/wav-trigger-downloads/)](http://robertsonics.com/wav-trigger-online-user-guide/#chapter6)](http://robertsonics.com/wav-trigger-online-user-guide/#chapter10)
