Wav trigger : using 16 physical triggers with different MIDI banks?
Hi internet,
I am working on upcycling a vintage organ pedal keyboard, to use it live with a good set of samples.
I soldered each of its 13 keys to the first 13 physical triggers of the WAV trigger. It works great and sounds great.
Now, can I use the 3 remaining inputs to trigger a bank change that would allow me to choose between different set of samples ?
I know that it would be easier to use midi via the serial port but that comes with its own set of difficulties (and learning curve). I also want to keep everything on one board to keep the project cheap.
there are probably already several topics on the subject, but me not being a native english speaker, I tend to miss a lot of infos along the way.
thanks
Cyril
You can certainly do that, you’d just assign the trigger as ā€˜trigger bank up’ and ā€˜down’, it is briefly covered on page 5 here https://cdn.sparkfun.com/assets/1/c/9/a/9/WT_UserGuide_20230114.pdf and here’s a thread with a screenshot of the menu in the configurator app
Well, I’ve already assigned a trigger for ā€œbank upā€ but the thing is that I don’t know how to ā€œfillā€ this new bank…
I’ve labelled my first set of sample 001 to 013, do I label the new bank 017 to 030 ?
Well, finally got it !
the trigger bank up function works just fine, I happened to have mislabelled my second bank, starting from 014 instead of 017…
thanks for the answer anyway !
