I am using OpenLog Artemis with the SAM-M8Q and I need help interpreting the numbers it records. The accelerator values are obviously in milli-g’s, the Lat and Long are degrees times 10^7, and GPS heading appears to be degrees * 100,000. But I can’t figure out the units and scale factor for the magnetometer, gyro, GPS altitude, GPS ground speed, and GPS pDOP. I couldn’t find anything in the docs on the site.
Hey, thanks for posting the units. After I posted that “acceleration is obviously milli-gs”, I realized I might be wrong – it could be m/s^2 * 100. Just want to confirm that you didn’t just go by what I said
Also, I thought PDOP was dimensionless, as it is a ratio.
