Topic.
What mounting/securing hardware is included with these products? If none, what hardware is recommended to secure equipment to test items?
Can the equipment be re-used numerous times for different test items?
Topic.
It highly depends on your application. For example, if you see this tutorial: https://learn.sparkfun.com/tutorials/io … e-and-case They made a wooden base for the system. Because it was for industrial use.
On the other hand, in case of bathroom scale https://learn.sparkfun.com/tutorials/lo … 1644156907
You can see the case is different.
