What is the layer order?
I am doing a 4-layer board, and I would really like the order to be top, ground, vcc, bottom.
I believe that works out to assigning GTL, G1, G2, and GBL. (Makes sense, but I wanted to check) It’s not critical, but the ground plane is much less cut up than the Vcc plane.
Is this the correct layer order?
-Seth
