I usually use BatchPCB and they are brilliant for the price and the quality you get, but I have a project that really needs a different color board that the usual green, and am having trouble even finding a fabrication house that offers them.
Anyone got any preferences to houses they use (I’m in the UK but doesn’t matter if have to use abroad services).
I understand the coloured part of the board is the solder resist, correct? So I am basically after alternate coloured solder resists. My first choice being white, but open to options.
None of the low-cost prototype services will be able to supply different solder mask colours, but any of the production board manufacturers should be able to do it. PCB Cart in China definitely can, and I’d have thought that Gold Phoenix can, as well.
PCBcart is probably the most cost effective, reliable and with the color options you wanted. I just placed an order exactly 8 days ago. Today it will reach my place! Awesome.
I am just awaiting the fastest delivery time available from OpenPCB and I should be placing the order. I must say their prices appear fantastic, 300off of my board (16x50mm 2mm thick in blue PCB) only $0.31p each, plus a $40 one off tooling cost. Compared to here in UK the best local I found yesterday capable of doing blue PCB is £204 for 104off (single panel) coming in at effectively over £2 ($3.14) per unit, due to a £80 panel setup cost.
However that said, once you go through the entire cart and get to the end with delivery charge of another $45 for standard 8 day it starts to push close to the UK cost, so if there faster lead time pushes the delivery or costs up much more it will in fact be close to the UK price, and I may end up going local with the benefit of future orders not needing the £80 tooling cost, and higher batches bringing down the unit cost.
could you please post a link to openpcb? googling for openpcb returns some irrelevant results. thanks
