Had me confused for a minute but then I moved the symbol and nothing was connected. What happened was you put the pins on the symbol backwards, with the connection end on the inside. I tried connecting the net to the inside end of the pins and it worked fine. All you need to do is flip them around in the symbol editor so the circles are on the outside where the connection is to be made.
