My goal is to connect to my server using the webclient sketch. First, I have been able to manually connect to my router using the terminal.
Next, I would like to prove that I can automatically connect to my router using the Autoconnect sketch.
My question relates to how the autoconnect sketch functions for me. After uploading it to the board, my green light fast blinks indicated that it does not sense an IP address. When I open the terminal, I only see “WiFly Shield Terminal Routine” and nothing else. It is as if the “exit” command has not been entered into the terminal after attempting to connect manually.
Does someone have a suggestion for troubleshooting this problem?
I hope to confirm connection to my router with a slow blink.
Andrew
