I’ll try to put it simple.
I want to be able to continuously read 6 analog ports and send it values (TCP/IP or UDP… I don’t care) from WiFly shield (connected to arduino uno) to a wifi node at a rate of 115 200 bps.
Do you think it’s possible?
thx
JP
              No, the firmware (both WiFly and Arduino) is too buggy. There are many other posts in these forums regarding the problems that people have encountered.
              Thanks for the reply.
Any other solution known to work for this application?
Any ethernet to wifi bridge that could connect with ethernet shield do to so?
What about other modules? (GHI rs21 module combined with fez spider for instance)
Thanks for your help.
