wiggler, cfi - intel compatible, Arm 7, beginner, Flash prob
I’m now using an Arm7 based display controller with the olimex wiggler.
I’ve got most the configuration right but i’m struggling a bit on the flash, i’ve got it going using my normal ide and jtag but not on openocd. any idea what i’m doing wrong? Thanks.
The flash attached is intell command compatible M28W640FCB, 64Mbit (4*16)
the mww were the registers that needed setting to configure the LH75411 to use the flash.
Script:
#remap
mww 0xfffe2008 0x00000000
#hclk
mww 0xfffe2018 0x0000000F
#disable watchdog
mww 0xfffe3000 0x00000000
#set chip selects
mww 0xFFFF1000 0xEFFF0010
mww 0xFFFF1004 0xEFFF0010
mww 0xFFFF1008 0xEFFF0010
#SET IO CON MUX
mww 0xFFFE5000 0x00007FFF
flash protect 0 0 70 off
flash erase 0 0 70
flash write 0 Disp.bin 0
reset run
shutdown
Config:
telnet_port 4444
gdb_port 3333
interface parport
parport_port 0x378
parport_cable wiggler
jtag_speed 0
jtag_nsrst_delay 100
jtag_ntrst_delay 100
reset_config srst_only
#jtag scan chain
jtag_device 4 0x1 0xf 0xe
daemon_startup reset
target arm7tdmi little run_and_init 0 arm7tdmi
run_and_halt_time 0 1000
working_area 0 0x60000000 0x4000 nobackup
#flash bank <chip_width> <bus_width>
target_script 0 reset Myscript_LH.script
flash bank cfi 0x40000000 0x4000000 2 2 0 0x60000000 0x4000
Log:
Debug: jtag.c:1210 jtag_init():
Debug: parport.c:373 parport_init(): requesting privileges for parallel port 0x378…
Debug: parport.c:383 parport_init(): …privileges granted
Debug: parport.c:210 parport_reset(): trst: 0, srst: 0
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1096 jtag_reset_callback():
Debug: openocd.c:100 main(): jtag init complete
Debug: arm7_9_common.c:656 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 0
Debug: parport.c:210 parport_reset(): trst: 0, srst: 1
Debug: arm7_9_common.c:722 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 2
Debug: openocd.c:104 main(): target init complete
Debug: openocd.c:108 main(): flash init complete
Debug: gdb_server.c:1347 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:157 embeddedice_read_reg_w_check(): 1
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 3
Debug: arm7_9_common.c:838 arm7_9_halt(): target->state: running
Debug: embeddedice.c:253 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:253 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:253 embeddedice_write_reg(): 13: 0x000000f7
Debug: arm7_9_common.c:620 arm7_9_poll(): DBGACK set, dbg_state->value: 0x9
Debug: embeddedice.c:253 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:944 arm7_9_debug_entry(): target entered debug from ARM state
Debug: arm7_9_common.c:976 arm7_9_debug_entry(): target entered debug state in Supervisor mode
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r0: 0x000000d3
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r1: 0x00007fff
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r2: 0xe0022003
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r3: 0xe2511001
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r4: 0x1afffffb
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r5: 0xeafffffe
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r6: 0x50d4ccd0
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r7: 0xdc60062a
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r8: 0x2012525c
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r9: 0x99d4c464
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r10: 0x00a40655
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r11: 0x204a2671
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r12: 0x5194281d
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r13: 0x3d1400a0
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r14: 0x00002004
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x00001a74
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x1a74
Debug: target.c:442 target_call_event_callbacks(): target event 0
Info: target.c:219 target_init_handler(): executing reset script ‘Myscript_LH.script’
Debug: target.c:1254 handle_halt_command():
Info: configuration.c:50 configuration_output_handler(): requesting target halt…
Debug: arm7_9_common.c:838 arm7_9_halt(): target->state: halted
Warning: arm7_9_common.c:842 arm7_9_halt(): target was already halted
Info: configuration.c:50 configuration_output_handler(): target already halted
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0xfffe2008, size: 0x00000004, count: 0x00000001
Debug: embeddedice.c:253 embeddedice_write_reg(): 0: 0x00000004
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0xfffe2018, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0xfffe3000, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0xffff1000, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0xffff1004, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0xffff1008, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0xfffe5000, size: 0x00000004, count: 0x00000001
Info: configuration.c:50 configuration_output_handler(): sector number(s) invalid
Info: configuration.c:50 configuration_output_handler(): failed writing file Disp.bin to flash bank 0 at offset 0x00000000
Info: configuration.c:50 configuration_output_handler(): unknown error
Debug: target.c:1328 handle_reset_command():
Debug: arm7_9_common.c:656 arm7_9_assert_reset(): target->state: halted
You have to run “flash probe” after you’ve configured your external memory interface, but before you’re accessing other flash functions.
The last two arguments to the “flash bank” are bogus - they’re correctly specified in the working_area line, and aren’t part of the flash bank configuration.
Regards,
Dominic
Thanks Dominic,
i have ammended the script to call:
flash probe 0
before it calls flash erase and the flash bank to:
but its still failing on the probe is the 2 2 0 correct for 16 bit addressing (i’ve also tried 1 1 0)?
Log lines around the flash probe:
Warning: arm7_9_common.c:1963 arm7_9_write_memory(): memory write caused data abort (address: 0x40000000, size: 0x2, count: 0x1)
Debug: arm7tdmi.c:506 arm7tdmi_write_xpsr_im8(): xpsr_im: d3, rot: 0, spsr: 0
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0x40000000, size: 0x00000002, count: 0x00000001
Info: configuration.c:50 configuration_output_handler(): probing failed for flash bank ‘#0’ at 0x40000000
Thanks for your help:)
Your chip is generating data aborts when the OpenOCD tries to write to the Flash address (0x40000000) to enter CFI query mode.
The values you’re writing at 0xFFFF100[0,4,8] (0xEFFF0010) seem completely bogus according to the user’s manual, make sure you’re setting them correctly. I guess the data abort occurs because you’re setting WP (bit 26) to 1.
The size your specifying for the flash bank is wrong, too. Your 64Mbit device has 8MB, but you’re setting it to 64MB size. The correct value for 8MB is 0x800000.
Regards,
Dominic
oh rats ok you’re right i got it back to front,
EFFF0010=>1000FFEF
I’ve changed the memory to what you said too.
and i’ve added lines to the script to set the pc =0 and cpsr =0xd3 as the script in my other ide was doing.
i still have a problem though:
Debug: cfi.c:887 cfi_probe(): CFI qry returned: 0xffffffff 0xffffffff 0xffffffff
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0x40000000, size: 0x00000001, count: 0x00000001
Info: con
Sorry to be a pain but can you see anything else i’ve missed?
[Edit]
Found that problem i was using:
flash bank cfi 0x40000000 0x400000 1 1 0
when i should have been using
flash bank cfi 0x40000000 0x400000 2 2 0
That cfi’s fine now however when i try to program it says low programming voltage detected, Operation aborted
:? Any Ideas?
Please send the complete log and the .cfg you’ve used to Dominic.Rath@gmx.de.
Regards,
Dominic
