I’m working with the Sparkfun Pulsed Radar A111 breakout board, and it’s working well on a Rpi 3B.
Will this also work on the Rpi Zero?
I’m not making frequent requests of the A111 - only accessing it every 3 seconds or so, which is low usage for this board.
Thanks in advance.
It’s not been tested on the Zero but I don’t see anything obvious that would make it not work. Go ahead and give it a try and let us know how it goes!
The A111 Pulsed Radar Breakout is designed to sit directly on top of a Raspberry Pi. Again, it doesn’t span all 40 (2x20) pins of a Raspberry Pi B+ (or later), but the 26-pin — 2x13 — header should be compatible with any Pi.
