Hello!
Per the Arduino fio programming page, it indicates that in addition to wireless programming, the fio can be programmed via a FTDI adapter or an external programmer.
http://arduino.cc/en/Main/ArduinoBoardFio
My question is, if an xbee is installed, would it need to be removed each time you use the FTDI adapter, since it uses the same RX / TX pins as the xbee?
Thanks.
Paul G.
