I am trying to use a Wireless Motor Driver Shield (DEV-14285) with a RedBoard Turbo. I removed the 5V pin and connected the boards 5V to the 3.3V line. I have not plugged it in yet as I don’t want to damage anything. Will this work and allow the serial line to work with the XBee socket?
Dale
Hello tech-mech,
If the voltage has been altered to be 3.3V then nothing should fry. I think you'll be ok with that.
Yes, the Xbee's are shifted for 3.3V logic anyway, they should still work.
