Hello, Greetings!
I am a beginner in this field. I have the XA1110 GPS sensor with SBAS enabled for accuracy <2.5m. I am currently looking for a suitable antenna (through-hole) as I am going to place the sensor inside a closed box.
Can anyone please guide/suggest/advise which antenna would be suitable for these applications or give me insights?
Thank you!
You can view a variety of compatible antennas on the XA1110 product page under the section “Hookup Accessories”. However, my favorite has been https://www.sparkfun.com/products/15960
Hello sir,
Thank you for your revert. Can you please explain why did you choose this particular option?
Are there any alternatives with longer wire?
Please advise.
Thanks and regards.
For myself, it was a cheap flexible option for quick prototyping and I got a good signal connection. The most reliable, long length, option we carry (in my opinion) is https://www.sparkfun.com/products/14986. However, it will need an adapter (https://www.sparkfun.com/products/9145) and may not fit all applications.
