I have 2 Xbee 3 modules. All indications is that they are talking to each other and when I change the state on the input of DIO4 for unit A and monitor the state of DIO4 on unit B, I get the blue led but no change in the output for unit B on DIO4.
I have gone thru XCTU’s “Configure the XBee modules” with no joy.
Thank you. I did this, but still no joy on pin paring. Every thing appears to work, but monitoring out put on DIO4 with it set for output hi. No changes. I can change the state of this pin with XCTU.
Would it be possible for someone at Spark Fun to verify that I am the only one experiencing this?
You definitely need to load the 802.15.4 firmware on a XBee 3 to consider this, that should make your XBee 3 emulate the XBee series 1 the tutorial was written for.
