Does anyone know of a port for the ansi c library?
The arduino xbee api library out there does not cover xbee series 3 boards to which i which the xbee cellular modem is.
The arduino tiny gsm only covers command mode and not api so functionality is limited.
Any thoughts or suggestions?
Closest I found was this https://github.com/digidotcom/xbee_ansic_library - check it out and see if this is what you’re looking for?
This is not ported for Arduino. I was told by Digi this is because Arduino does not support RTS/CTS but some arduino boards to so…not quite sure where this comes from.
THanks
Bruce
