I’m working on making 2 Arduinos communicating with each other with XBees. But currently having problems.
Hardware:
2x Arduino Uno
2x Arduino shields ( https://www.sparkfun.com/products/22131)
2x Xbee modules ( https://www.sparkfun.com/products/22630)
2x SMA antenna
My steps:
Configured the XBees successfully with XCTU with the same parameters in this post: https://learn.sparkfun.com/tutorials/ex … /all#xbee3
Plugged in everything in the same way as in: https://learn.sparkfun.com/tutorials/xb … e-overview
Flashed both Arduino with the same code as in: https://learn.sparkfun.com/tutorials/xb … e-overview
Plugged both Arduino to power, then the blue LEDs on both shields start to blink twice per second, which according to this post (https://docs.sparkfun.com/SparkFun_Digi … rview/#pwr), means “the last TCP/UDP/SMS attempt failed”, and I should check “DI (Remote Manager Indicator) or CI (Protocol/Connection Indication)”
Questions:
Is there anything else that needs to be configured to make this system work?
How to check “DI” and “CI”? It looks like they are not XBee config parameters. And what does “good value” for “DI” and “CI” look like?
Thank you for your help.
