I’m having difficulty with the initial setup of a basic xBee network for Arduino with XCTU
I went through the https://learn.sparkfun.com/tutorials/ex … s-and-xctu tutorial with no success.
Here is my setup:
Macbook Pro with OSX 10.14.6
Arduino
USB 3.0 USB Hub
USB Dongle Explorer
xBee S1
I tried 3 different ways with no luck:
Default OSX FTDI Drivers - Could not locate explorer board in XCTU or Arduino IDE as a serial port
VCP Drivers 2.4.2 - same issue (https://www.ftdichip.com/Drivers/VCP.htm)
SiLabs USB to UART VCP Drivers (https://www.silabs.com/products/develop … cp-drivers)
I plugged in an Arduino Uno through the same USB hub and was able to locate it in Arduino IDE in the port drop down with no issues.
I’ve attached some pictures that may help. If other info would be helpful I could most likely provide whatever you need.
