xbee series 2 modem failure
you cant believe, i’ve tried every other possible way that i found in this forum (and internet as well!). nothing worked. if i tried with api mood its can get the modem withou version and therefore cant write the firmware. if dont api mood, its simply cant communicate (unable) with the modem.
however if i tried to reset (without api mood) and follow the instructions (found in the forum about reset), it tried but finally said failure to write, lost communication with the modem. check your baud rate. i fixed it for 9600 (both pc settings and from computer serial port settings). too frustrating!
any solution pls??? :frowning:
if you want to know more details (about the steps or specifications!) pls let me know. i was trying for 4 days…
one more thing. its worked very well before. but just when i tried to run the robot, its stop working and everything was gone! since then i was trying to fix it…
i’ve attached the images (screen shot) for your better understanding…
please please suggest me something. 2 of my xbees are gone!!!
http://www.postimage.org/image.php?v=aVpvT9r
http://www.postimage.org/image.php?v=aVpvVEA
http://www.postimage.org/image.php?v=Ts1hn190
http://www.postimage.org/image.php?v=aVpvY8J
http://www.postimage.org/image.php?v=Ts1hn3E9
anyone please please please… almost gone mad on xbees!!! start dreaming nightmares! :x
Call Digi Int and open a trouble ticket.
waltr:
lol, may be the easiest solution! thnx mate. i am still trying by myself…
