Xbee Transmission problems
Hi Guys
Ok having set up my 2 xbees, im getting a weird problem. Data is going fine from router/end device to co-ordinator but not the other way.
If i try to send data from co-ordinator to router/end it either fails completely or is massively delayed.
Any ideas??
Cheers
ben
Seems the exact same problem as this guy is having…
viewtopic.php?t=14455&highlight=xbee+transmission
sorry I can’t help as these are Series 2 XBees that use the Ember chipset (I have no experience with these)
The Series 1 are intended for non-ZigBee applications, though series 2 reportedly can also do wireless UART emulation. I think Digi’s firmware for this is essentially the same as for Series 1. But it may be that most users of series 2 (Ember) products are using ZigBee.
Hey Stevech, Its Ben from the zbasic forum.
Thanks for your response, im running out of ideas here. So are you saying there is a different firmware package for wireless UART, cant see anything on their site.
Ben
Try this solution:
viewtopic.php?p=69011#69011
modles:
Ben
Digi has wireless UART firmware - I think it ships as the default in Series 1. Perhaps Series 2 ships with ZigBee as the default; I don’t know.
Thanks etracer, this worked a treat!
