Love these units. Base and Rovers working fine. Search the forum but couldn’t find this info explicitly.
Question is … if I pull the Reset line low to start things over, does it clear the last fix data? Essentially erasing the hot fix positioning.
The BBR (Battery Backed RAM) is supposed to maintain.
In most cases you really should need to be using NRESET unless you’ve RAM configured a change in baud rates, and message mix.
To clear settings, look at UBX-CFG-CFG
Yes, have the CFG file set with the normal changes for a Rover etc. The robot it’s on has a number of components that sometimes get out of sync and the main CPU does a master reset dropping a circuit that several devices connect to. Was thinking I would tie the ZED-F9P unit reset to that line. I probably should test it thoroughly to see if it helps or hurts. Thanks though.
Would like to know how that worked out please. I’m considering doing the same thing.
