ZED-F9P RTK system takes too long to find distance between Moving Base and Rover
OK - thank you.
It may be due to the position and orientation of the satellites in the sky, on that particular day at that particular time. Please see the post below for more information. +/-0.5cm is very close to what is possible with RTK. If a tolerance of +/-1cm works better, I would suggest using that.
