ZigBee with RP-SMA
Is there a ZigBee module that has an RP-SMA connector for the antenna? I would like to use a MaxStream ZigBee PRO module for wireless communication between robots, but I want to use an external antenna if possible.
8-Dale
They have modules with a different connector — a “U.FL connector” — which is a bit smaller than an SMA.
wiml:
Hmmm, I have to check and see if SFE has antennas with that connector.
8-Dale
The U.FL connector is the same one found on all mini-PCI wireless cards - if your laptop has a built-in wifi, chances are it has a mini-PCI wireless card with a pair of U.FL connectors. You can buy pigtails that turn U.FL to RP-SMA from many sources.
