I am planning to use external antenna(Circular polarization 6dbi). The cable of my uhf antenna is sma female. So i connected u.fl to sma male cable to the m6e nano board, then connected the sma male to sma female of the antenna. Is this correct?
The M6E uses RP-SMA, not regular SMA…RP is reverse polarity; see the guide for more info
But otherwise yes ![]()
Here’s all of our RP-SMA stuff Search Results for rp-sma - SparkFun Electronics
You’ll likely just need RP-SMA to U.FL Cable - 150mm - WRL-18569 - SparkFun Electronics if I’m understanding correctly
Hi thank you for your help. I intend to use the following:
- U.fl to rp-sma female connector
- Rp-sma male to sma male adapter
- The sma male is then connected to my sma female antenna connector.
Thank you again for the response. I appreciate it
