I recently purchased the GPS breakout ZOE-M8Q (qwiic), U.Fl antenna (https://www.sparkfun.com/products/15246), and a Redboard (Qwiic). I’m using the Arduino library and examples provided on the Sparkfun ZOE-M8Q website but am not getting any info from any GNSS system. I’m programming the Arduino/Redboard on a Win10 machine w/ Arduino IDE 1.8.15.
Troubleshooting thus far:
Redboard works with separate PHT Qwiic sensor board. Sending info back to the serial monitor.
The red power led on the ZOE-M8Q is illuminated. when connected via Qwiic to the Redboard. The Redboard’s TX pin is flashing green indicating transmission. The green power led is illuminated.
The U.Fl antenna seems to be properly connected to the ZOE-M8Q.
I have the SparkFun_u-blox_GNSS_Arduino_Library properly installed.
uploading Example2_NMEAParsing to the Redboard results in no errors when compiling. When I view on the serial monitor it is continuously outputting “Waiting for fresh data” implying that nmea.isValid() is false. It does not acquire any satellites after running several minutes.
I found this recent post(viewtopic.php?f=116&t=55610) to check the PPS pin. I hooked my multimeter up to PPS (and connected COM to the Arduino GND pin). No cycling of high/low signals observed.
What other troubleshooting things can I try or do I have a bad board?
