ZOE-M8Q PPS
Hi! I have a problem shown in the picture with the PPS sign. In High frequency is nice rectangular sign (but why go under 0V ?!), but at a lower frequency terrible… I tried with 2 NEO-M8Q
The power is good (+/- 20mV noise).
With SparkFun_u-blox_GNSS_Arduino_Library/Example23_TimePulseParameters (v 2.2.22) it running without error message. I tried it with with SparkFun_u-blox_GNSS_v3, but nothing happens…
How is the scope connected to the module? Almost looks like a missing ground
The scope ground is on the common (power) ground.
I just noticed that the scope is set up for AC coupling. Try changing it to DC coupling.
/mike
Mea culpa… :oops:
I misinterpreted a parameter, so The PPS signal has not changed for a long time.
Then I switched to AC coupling…
It works excellent with good settings.
