1.5" Sparkfun OLED 128x128 not working
I have a 1.5" Sparkfun OLED 128x128 and Twist Rotary Encoder Combo that does not seem to work. The first day I got it, i plugged in the quick cables, and boom it was hot! They work separately but seem to get static when together. Serial Monitor right now its all glitchy. I’ve been trying for three days now. Would love a refund or a new one that works. Right now getting this:
”23:10:32.269 → Found 0x32
23:10:32.269 ->   Found 0x33
23:10:32.269 ->   Found 0x34
23:10:32.269 ->   Found 0x35
23:10:32.269 ->   Found 0x36
23:10:32.269 ->   Found 0x37
23:10:32.269 ->   Found 0x38
23:10:32.269 ->   Found 0x39
23:10:32.301 ->   Found 0x3A
23:10:32.301 ->   Found 0x3B
23:10:32.301 ->   Found 0x3C
23:10:32.301 ->   Found 0x3D
Ln 51, Col 1
SparkFun ESP32-C6 Qwiic Pocket
on /dev/cu.usbmodem1101
Them working separately makes me suspect an i2c pull-up issue (there are currently 3 sets of them active, the C6’s Hardware Overview - SparkFun Qwiic Dev Board ESP32-C6, the Twist’s and the OLED’s)…disable all but one set by severing the trace between the i2c jumper pads on 2 of the 3 items and re-test
If it’s still giving issues after perform an i2c detect/scan and post the results here :slight_smile:
