The silk screen for the 6-pin connection on the board reads:
STAT TRIG 3.3V RX TX GND
But the Schematic and the board layout diagram shows:
STAT TRIG 3.3V TX RX GND
i.e the TX and RX connections are reversed.
Which version is correct?
I’d go with the silkscreen (usually if there is a silkscreen error it gets noticed quick…schematics errors are harder to notice & fix)
Be sure to update this thread if that is not the case ![]()
Thanks! I’ll try that.
I tried it. The silkscreen is correct.
