Does anyone know if there is a 3D model available for the MicroMod Main Board?
We don’t have an STL/STEP, but we do have https://github.com/sparkfun/SparkFun_Mi … ard_Single
@rtalich You may be able to generate a 3D model of the PCB with the mounting holes in either Fusion 360 or KiCad, but I suspect you’re not going to have an easy time finding 3D models of the rest of the SMD components.
Russel, SparkFun doesn’t really seem to be prioritizing 3D models any longer (there used to be a 3D viewer for many products). I’m guessing far too much work to keep that up?
Cheers,
Adam
Thanks for the replies!
I was able to download Eagle from Autodesk and convert the .brd file to STEP. Imported into SolidWorks… but only got the PCB without components.
