45 Degree Turn in EAGLE
I want to place an IC {VS1002} diagonally between 2 headers in EAGLE. How do I do this. I don’t exactly know if I’m explaining correctly so here is an example. http://www.parallax.com/images/prod_gif/bs2px-ic.gif
In the command line, type rotate r45 (counterclockwise) or rotate r-45 (clockwise) then click on the component you want to rotate.
Don
Thanks this really helped in my smaller VS1002 board which has REAL tight routing.
donblake:
Don
Have you gotten a board thus designed to pass the DRC bot? I get errors about having too small an aperture.
