Hey just picking up the eagle software and trying to figure out how to rotate a part less than 90 degrees… I just need it to rotate in 6 degree intervals. Is this possible?
pick it up, then in the angle box on the top toolbar type in the value you want
Or, use the Info command and type in the angle field
Or, hold left mouse down when you select the component and move the mouse relative to the selection point
Or, type ‘rot r6’ then point to component
Or, type ‘help rot’
Thanks to both of you. I had tried typing in the angle box but as a complete moron that I sometimes am went to rotate the thing with the move command using the right mouse button so i would go back to 90 degrees. Thank God for people like you guys who have a a bit of sense to share.
