How do I use the Eagle ARC command
I have spent the day trying to understand how to use the ARC command in Eagle.
I want to draw a 90 degree arc with it’s center at 0.5, 1.7 and its radius 0.5 (units are inches here).
I want it to start at 270 degrees and end at 360 degrees. HOW!
Any enlightenment will be appreciated.
Vic
I sorta liked the EAGLE manual explanation; it made sense when
compared to the way the GUI arc command worked:
The ARC command, followed by three mouse clicks on a drawing, draws
an arc of defined width. The first point defines a point on a
circle, the second its diameter. Entering the second coordinate
reduces the circle to a semi-circle, while the right button alters
the direction from first to second point. Entry of a third
coordinate truncates the semi-circle to an arc extending to a point
defined by the intersection of the circumference and a line between
the third point and the arc center.
So if you have a center (X,Y) and a radius R and a thickness T, you
need a command like:
change width t; arc (x-r y) (x+r y)
(and then click to make the other endpoint)
Polar coordinates may also be useful; they’re relative to mark, and
generally a lot more convenient when you’re dealing with curves…
change width t;mark (x y); arc ccw (P R startAngle) (P -R
startAngle) (P R endAngle)
You might also look into the “wire” command, since in recent versions,
ARC are just a special instance of curved wires.
For your particular example, try:
mark (0.5 1.7); arc cw (p 0.5 0) (p -0.5 0) (p 0.5 270);
