7-Segment Red LED datasheet incorrect
Hey,
I’m curious as to whether I have different 7-segment or the datasheet is incorrect. I bought a http://www.sparkfun.com/commerce/produc … ts_id=8546# and it has the same markings on it as shown in on the sparkfun website, however the LED pinout is different then described in the datasheet.
The actual pinout is:
1 - E
2 - D
3 - Anode
4 - C
5 - RDP
6 - B
7 - A
8 - Anode
9 - F
10 - G
Anybody else notice this? The datasheet says the anodes are 5 and 10 which is definitely not the case.
Pins 3 and 8 are often used as the common pins on the Kingbright LED displays I’ve used. Perhaps that manufacturer has changed them to make them compatible with the better-known Kingbright ones.
Leon
