Hi everyone,
I am trying to use this Razor 9DoF IMU M0 (SEN:14001) to my arm cortex a_53 board and i need a linux code for that and i was unable to get it .Do any one has got one ? If so please help me.
Hi everyone,
Hi Sai.
I’m sorry, but we don’t have any linux code for this product.
The 9DoF Razor’s default firmware just outputs data via USB serial, so as long as your platform can see a serial port when connected to the USB connector on the board, you should be seeing data stream by. You’d need to write your own code to interpret the serial stream coming from the board and take action on it.
Thanks for the reply,
Can i cross compile any arduino source (for Razor IMU 9DoF)to arm ? If so can you please attach the links
We have no links for that and I doubt very much that the Arduino code will compile in Linux without some modification. We are not able to assist you with any modifications to our code.
