What is the measuring envelope for this board as far as velocity? Is the velocity envelope measurements software-based or requires hardware modifications (low-high bandpass filter) if the velocity is (for example) between 200-900 mphs?
What about the minimum size of metal objects measured within 10-30cm from the sensor at such high velocities??
