I think this is the cause of your issue:
I configure a new serail baudrate speed by pressing ‘any key’ + 4 + 4 and then set a configuration, like for example 9600
I check the configuration and indeed it appears 9600 bps
I reset using the reset button
The baud rate is only saved when you exit the main menu - by entering “x” twice.
Please try:
Configure a new serial baudrate speed by pressing ‘any key’ + 4 + 4 and then set a configuration, like for example 9600
Exit the menus by pressing x twice
Reset using the reset button
