ac switch/rf relay help to find
Hi i’m looking for ac switch w next spec:
Please see below the RF analog ac switch specification:
  • Operation frequencies: 0-20MHz
  • SPST or SPDT
  • Application: pass around 6W in Lo freq, block around 10mW in Hi freq
  • Close/on state (when around 3Vdc applied to the switch controls):
Can pass 6Watt, 25Vac pp @ sub 0.5MHz
  • Rds on: up to 200mOhm when switch is on state for minimal loss
  • Open/off state (when no any power applied to the switch- normally off):
Can block 25Vac pp @ above 10MHz signal w isolation around 20dB
  • Low profile: SMT part, preferably around 1mm height
  • Target price: up to 2$ per unit
