ADC for use with the Bluetooth DIP
Somewhat of a beginner question here: I want to use this device to transmit analog voltage readings to my PC. Can someone recommend an ADC chip that is compatible with the input of the Bluetooth DIP? I need at least 6 channels, probably want at least 12-bit per channel and 500Hz sampling rate per channel. I’m trying to avoid going the PIC route because all I need is A/D. Thanks for your help!
I would try an Analog Devices part. They have a parametric search that would help you pick the best part.
http://www.analog.com
