ADXL321 exposed pad
I am just wondering can I connect exposed pad of ADXL321 to ground? There is nothinng about it in specs, and usually there is some recommendation as in Kionix datasheets for example. Thank in advance for every advice!
It would normally be soldered as part of the reflow soldering process, using solder paste. For hand assembly, I put a large via in the middle of the pad and feed solder in with the soldering iron tip.
Leon
Thanks Leon! But the interesting thing for me especially is does someone connect this pad to GND (ground) or leave it NC (not connected, standalone) as a pad ?
I would ground it. I have on the similar chips I’ve used.
Leon
