This is a fantastic little device that will quickly replace the ADXL311. Expect many new consumer electronic devices to ‘know’ when you’ve picked them up.
I am replacing a ADXL250 that isn’t working well in my system, and has been discontinued anyway. I am planing on ordering the analog devices breakout board, and the freescale board to compare them. I would like to get the ADXL in the ±5g and ±2g versions.
It looks like the breakout board can be ordered assembled with either the 320 or the 321. How about the ±2g ADXL322?
What case size are the capacitors in case I order the bare PCB, and get the 322 elsewhere?
Does anyone know when the 3 axis Analog Devices part (ADXL330) is going to be available?
How do you mount the thing? The leads are all under the edge of the IC, and there appears to be an exposed pad on the underside of the part that the data sheet does not call out. What is it supposed to connect to?
I was thinking of extending the pads on the PCB out from under the part, and then using them to reflow solder to the pins. But what about the large pad that is completely under the part?
I got two of the development boards and I had to reflow one of them using a heat gun because it wasn’t soldered down completely.
Should I just resign myself to sending this assembly out to a pick and place shop?
Tyler:
The pad should probably be connected to ground. An easy way to connect it is to have a grounded copper area on top of the board, under the chip, and put a via in it. You can then feed solder into the via from the underside of the board whilst heating it with a soldering iron tip. A large via might help.
Tyler:
perryrowe:
If I want to use this board , is it necessery to use another opamp before ADC?
It should have enough output not to need it. I am using the Freescale three-axis accelerometers (analogue output) with an MSP430, and there is plenty of output for the ADC.
