Is ADXL E8 Breakout Board Available Alone?
All listed products on Sparkfun show an associated accelerometer included. Is this breakout board available independently?
L
Way back in the day (~2005) we offered bare ADXL boards. Now that Analog Devices has moved to the much smaller, tighter SMD packages, we’re concerned that it would be very prohibitive for a user to try to hand solder the ADXL samples. If you know what you’re doing with hot-air, it’s possible, but tricky.
Tell you what - I’ll post our Eagle files. That way you can have the boards made yourself (go BatchPCB!).
http://www.sparkfun.com/commerce/produc … cts_id=847
http://www.sparkfun.com/datasheets/Sens … -Eagle.zip
-Nathan
