Alarm circuit which components to use?
I need to help modify this circuit for battery box 3x 18650 (total is 11.1V)
https://www.circuitstoday.com/wire-loop-alarm
https://www.amazon.com/Sackorange-Batte … B071ZQ2X2T
[Original components for 9V]
1x condenser: 0.1 uF
1x resistor: 100K
1x resistor: 4.7M
1x MOSFET: 2N700
my buzzer is at 5-12V I would like to power it 11.1V (box 3x 18650)
can you please advise me which electronic components should i use? (I’m not sure how to calculate it) what components do i need for 11.1V?
I want the batteries to last as long as possible in idle mode.
Thanks.
You don’t need to modify anything, your 12 volt buzzer will work just fine at 11.1 volts.
