Hi there,
Do you know of any vendors that sell, in small quantites, LEDs (201, 402, 603) with the Forward voltage of (Vf=2 V) or smaller and current of I=20mA? I buy in 100 or 200 pieces of each. Thanks
Hi there,
Farnell and RS probably stock some of those.
Leon
leon_heller:
Farnell and RS probably stock some of those.Leon
Thanks Leon,
Do you have their Web address? Thanks
smdFan:
Hi there,Do you know of any vendors that sell, in small quantites, LEDs (201, 402, 603) with the Forward voltage of (Vf=2 V) or smaller and current of I=20mA? I buy in 100 or 200 pieces of each. Thanks
SMD,
Not to put a damper on your question. You did, what I am guilty of. You didn’t give enough information to answer your question.
Where are you located?
If you are in the US…Digikey or Mouser, both sell online and sell relatively small quantities. Digikey does have an order minimum ($20), but it is easy to reach.
James L
propellanttech:
smdFan:
SMD,
James L
Hi James,
I am located in the USA. I am aware of all those vendors and many more. But lately I did not have good luck. I want to do all my orders together but some times they do not have all of them. Right, now I do not want to order large quantities so I look for vendors that accept small order.
smdFan:
Hi James,I am located in the USA. I am aware of all those vendors and many more. But lately I did not have good luck. I want to do all my orders together but some times they do not have all of them. Right, now I do not want to order large quantities so I look for vendors that accept small order.
I understand. It is hard finding a vendor that has everything you want in stock. I usually find myself ordering from at least two vendors to get everything I’m looking for.
I usually order from mouser or digikey…between them, i can usually fill out my parts request.
I like having the extra, because I know I’m going to build more than one anyway. I also try to use the same passives in all of my designs. It make it much easier.
I wish I could be of more help…but I don’t know of any other suppliers that carry a good selection without minimum order requirements.
James L
smdFan:
Try http://www.buy-leds-online.com/ , they are the distributers for a chinese manufacturer. I have not ordered from them, only their china group a couple of years ago. They were easy to work with.
muntron:
smdFan:
muntron,
I just ordered some LEDs, I hope they are good. I will let you know. Thanks
