A couple of questions:
I want to make a part in EAGLE like this:
http://www.gutwin.org/wheels.png
They’re a bunch of circular contacts (the entire area in the circle is not covered by mask) that make up a rotary encoder.
I’m having two problems, though. The first is that when defining a library part in EAGLE I can’t seem to make EAGLE recognize that I want the curved sections electrically equivalent to some SMD pads that are hidden under the traces. In the Layout editor you can use the NAME command to name a trace the same as a predefined signal, but that doesn’t seem to work in the Library editor.
The bigger problem, though, is that when EAGLE renders the arcs to a Gerber, they come out as many little lines with an aperture of 6 mils. Obviously this is a problem for the BatchPCB DRC bot. Aside from tweaking the aperture directly, is there any workaround to this (or some way to fix the bot itself?
-Karl
