Is an Arduino Duemilanove compatible with a GE865 Evaluation Board?
I previously asked about a problem I had with interfacing these two devices (viewtopic.php?t=19858) but didn’t get any response.
I have still not been able to get a response from the GE865 when sending commands from the Arduino and am now doubting whether they are compatible with each other.
Can anyone confirm that they have used both devices together successfully?
(Note: I have cleared the USB jumpers and connected the GE865 serially with the Arduino via a 5V to 3.3V logic level converter)
Static87: Is an Arduino Duemilanove compatible with a GE865 Evaluation Board?
I’m going to be doing the same thing however I believe the Telit using a 2.8 volt logic level…not 3.3…
