I’m trying to find an Arduino Uno compatible RFID reader that has a range of 2-3 feet with a keychain tag. Does this product exist? I want to attach the tag to my dog’s collar and have an actuator open a lid when the dog is 2-3 feet a way. I need the longer range because it will be difficult to teach them to stand in an exact spot a couple inches from a reader.
Thanks for the help!
Alignment and RFID are really two different things. I suppose if your alignment requirements are +/-2m, a 1m range would work. Any RS232 reader should work with Arduino & for your knowledge I have also put a link where you can get the product.
https://arduino
Thanks I hope it help you out. Good Luck.
AyeshaSalman:
https://arduino
Thank you for the reply! Can you please repost the link to the product you are recommending? The first one does not work
We carry our [Simultaneous RFID Reader and with an external antenna, 1 meter range shouldn’t be to hard to get. We don’t carry small ‘dog tag’ style RFID tags, but any EPCglobal Gen 2 tag will work. [Atlas RFID Store would probably have a tag that would work for you.](Search Results | atlasRFIDstore)](https://www.sparkfun.com/products/14066)
Unfortunately long range RFID is quite expensive and we don’t carry anything less expensive. The antenna we carry for our board is part number [WRL-14131 and our [hookup guide goes over how to use both the board and antenna.](Simultaneous RFID Tag Reader Hookup Guide - SparkFun Learn)](https://www.sparkfun.com/products/14131)
