Arduino Pro Mini
Hello all!
My RAW power solder point is completely missing. Is there any other (easy) solder point I can use to send 9v to power the board?
http://xs.to/image-AF51_4BC117D6.jpg
Check the schematics for a cap (or other component) connected to the RAW power. Then solder a wire to the cap terminal.
Thanks for the tip! I found a way in right at the voltage regulator!
