Arrays in gerbmerge (or others)
I see in the “to dos” for gerbmerge there’s a line: “# Implement simple primitive for panelizing a single job in an array”
Does that mean its not yet possible to array a board with a single design using gerbmerge yet?
If it is possible how would one go about doing it?
If not is there another low cost (free) way of panalizing a board in an array?
by array, do you mean same art repeated (aka step and repeat)?
if so, just do a relative manual layout and repeat the same job multiple times.
Yes, repeated, as if you were going to stuff it via pick n place.
I figured it out using a layout file!
http://claymore.engineer.gvsu.edu/~ster … tfile.html
10x10 grid:
Row {
  Col {
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
  Col {
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
    Proj1
(8 more times)
works goood
