Artemis RedBoard Nano Wireless Transmission
I am now getting some info about a Transmitter/Resceiver for a project i am working on. On the site of SparkFun i saw this nRF24L01+ Transceiver Hookup Guide whitch is really interesting, but by using the Common RedBoard, it will be a little too large.
My question will be if it is possible to do the same thing, what’s written in this Guide, with a RedBoard nano. This is to make it a bit smaller so it doesn’t take too many place.
You may need to modify the connections and code a bit but there isn’t any reason why the nRF24L01 won’t work with the Artemis.
We haven’t tested these two products in combination, we recommend prototyping on the RedBoard Qwiic first and then moving to the RedBoard Artemis Nano.
If your goal is just to make things small and compact, you might consider using the [Arduino Pro Mini, that will work with the nRF24L01 with no modifications to code or connections.](https://www.sparkfun.com/products/11114)
